removing stock exhaust bracket
Old May 11, 2012 | 04:20 PM
fRESH88's Avatar
fRESH88
Default removing stock exhaust bracket
whats up fellas, im going to be removing the stock exhaust bracket this weekend from the ride. Im a bit nervous because it seems the same bolt holding bracket is the same bolt holding my swing arm. is there anything I should do or worry about when removing this thing? any info helps
Old May 11, 2012 | 04:29 PM
08Nighttrain's Avatar
08Nighttrain
Should not be any problems just be sure to check clearance on the bolt when you put it back on as it will be slightly longer due to thickness of the bracket. Also looks like your passenger peg will be much shorter and you may need a new bolt for that.
Old May 11, 2012 | 05:35 PM
ghostrider69's Avatar
ghostrider69
Since it has a bolt on each side I would place a floor jack under the right side of the frame and jack it up enough to take some of the weight off of the bolt before attempting to break it loose.
cf7go
Mar 22, 2025 01:31 PM
live4rut
Sep 18, 2010 09:00 PM
rcaddell
Sep 16, 2009 02:32 PM
stinkfist
Feb 2, 2008 06:17 PM
DougM
Jan 1, 2008 02:16 PM
