Fatboy Exhaust bracket removal. HOW DO I?
Old Aug 30, 2010 | 05:22 PM
cf7go's Avatar
cf7go
Default Fatboy Exhaust bracket removal. HOW DO I?
How do I get this exhaust bracket off? As you can see I no longer need it. I am guessing that the swingarm bolt comes off? Can I just take that bolt out easily? Any help would be awesome! Sorry about the dark and dirty picture.
Old Aug 30, 2010 | 05:26 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You will have to pull the big bolt and the one holding the rear footpeg on.
Drew
Old Aug 30, 2010 | 05:33 PM
cf7go's Avatar
cf7go
will it come straight out without the swingarm getting all cocked in the frame? Will I need a spacer to put it back in?
Old Aug 30, 2010 | 05:36 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I am not sure. It looks like it will come right out but it has been a while since I removed a stock exhaust bracket.
Drew
Old Aug 30, 2010 | 05:45 PM
snook592's Avatar
snook592
That bolt shouldn't be holding the swing arm together. Pull it, then remount the peg
Old Aug 31, 2010 | 06:33 AM
tk353's Avatar
tk353
that is a 96. on the newer one the bolt does not come out as it uses the 2 lower bolts and the foot peg bolt. research some more
Old Aug 31, 2010 | 04:04 PM
cf7go's Avatar
cf7go
Mine is a 96. And I am pretty sure there's two separate bolts holding the swingarm in. That is why I am asking if I take one out with the swingarm get a ****-eyed in the frame. Guess I'll just have to try. Just thought someone here would know....
Old Mar 21, 2025 | 01:28 PM
biczeq's Avatar
biczeq
Have you ever pull it out? I have the same need and can not find the instruction anywhere.
Old Mar 21, 2025 | 02:57 PM
YZR's Avatar
YZR
15 year old thread and the OP hasn't posted in 13 years.
Old Mar 22, 2025 | 01:31 PM
Dogs57's Avatar
Dogs57
I've done it several times.There are 2 bolts holding the swing arm on. You can take the one side out to remove the exhaust mount. First, the bike has to be level. The back wheel must be sitting on the ground, but not have the weight of the bike on it. Remove the bolt and the mount. The swing arm should be where it needs to be to reinstall the bolt. If it's off a little you can move the swing arm around to line it up. Tighten the bolt and you're good to go.
johnv50
Jun 26, 2014 05:38 AM
patsfan05488
Jun 5, 2013 07:11 PM
fRESH88
May 11, 2012 05:35 PM
stinkfist
Feb 2, 2008 06:17 PM
FLSTF
Jan 19, 2008 06:56 PM
