Fat Bob Front Wheel Install Kicking my butt!
Powdercoated the wheels and installed new tires. I'm trying to reinstall the front and it just won't line up right to reinstall the brakes. No matter how I doe it and which side I put the spacers on it's too far to the right!?
Any expertise or tricks of the trade on this?
There should be a larger one and a smaller one.
The larger spacer goes on the left side (left while sitting on the bike).
George
If you're only off a little it's possible the pads closed in and won't let the caliper slide over the disc. Try gently spreading the pads open to get more space between them until you can slip it on over the disc (you may have to pull off the master cyl cap). Once the caliper is back on, squeeze the brake lever a couple of times to reseat the pads. Hope you get it worked out.
JoeBobber
07-23-2018 01:44 PM
