Why is it so slow??
Why is it so slow??
I have a '06 wide glide, 88ci with a six speed. I have bags and a National Cycle Sportshield EX on it and that's it. The bike starts and runs great, it just runs out of steam at 90 to 95 mph in 6th gear. I'm not sure whether the fact that I weigh in at about 235 is a factor or not. Maybe I should try to top out in 5th gear, I don't know. I had a '85 FXR that was 80ci and I know it would run faster. Does anyone have any ideas on this . In the wind.
Pops
Pops
You can "Cam it", maybe some SE 255's and get more out of the top end. But, the fact of the matter is; the way it sits, that's about all it's worth!
I have a '06 FXDi (Super Glide) W/ stage 1. That is; a SE air intake kit w/ V&H big guns (staggered) exhaust, a remap of the ECM and, a set of "Trick" heads and I can get 118 MPH out of 6th gear (Flat Out)(Yes,...I Broke the magic)!
The bike will do almost as good in 5th as it does in 6th......But, here's the fact of the matter, IMO....
You are expecting too much out of your bike. Enjoy it for what it is. I'll cruise all-day long at 80-85 MPH and arrive in good shape! Knowing full well that I can do that the next day....and, the next day.... You get what I mean?
With performance....You give up reliability to some degree. Either that.....or, You end up drivin' around like a "Mad man" angry at the world to run you bike the way you built it to run...
Can they (HD's) do it? Sure! Is it worth it? You decide....I'm 230 Lbs...My bike has close to 140K mi. on it and it's still on the origional bottom end in the engine and the origional primary and clutch and, I'd have no problem riding it from Georgia to Sturgis tomorrow if I wanted to.
Just sayin'....
Best wishes....Tim(HT)
Just sayin'....
You are running out of torque.
The sixth gear is just stacked on top of the 5 speed that already existed. Harley did not re-gear the transmission. They just added sixth on top.
Drop down to fifth and make your run. By 100 you will be out of steam anyway. Bags, windshield and 235 lbs is a lot to push.
The windshield has a lot to do with it, the weight too, but to a lesser extent.
100 MPH with the apes on my bike is fun for about 3 seconds.
BTW, the SE255 is the wrong cam for high end power. I have it and love it, but it's made for torque and doesn't produce a lot at high revs.
On the plus side, it has a really flat torque curve that starts early with a lot of *****.
It is however nice to 4200 rpm which is where most of the fun is. But I wish they had told me that before the build, I could have chosen another cam. She can still do about 118 top end, but that's it. I used to get more out of her, but the lower end makes up for that, and like you said high speed is fun for 10 or 20 seconds, I don't have apes! lol
I found that out the first time I opened her up to see how much I'd get with the new upgrades....disappointment!
I'm not at all disappointed in the SE255, but I knew what I was getting into.
Thanks for all the feedback. It makes me feel better to realize that I'm probably getting the best out of it that I can expect. You are right in saying that 100+ mph wears a person out real fast. The only thing I have realy done to the bike is have the alternator rotor bolts welded so it should last quit a while, well as long as I will probably ride anyway. At 73 I just had to make one more fast run and I guess 95 was fast enough for old people anyway. Again, thanks for the input. In the wind.
Pops
Pops
