How far can I go without a tune?
Long stort short the local stealership wants WAY to much money to tune my bike after putting in cams. I have a stage one with the sepst and has been dyno tuned for the stage one. My question is I will be getting the cams installed next week and its about 20 miles from my home so I have to drive it home without being re-tuned and I am thinking I am going to have it tuned at Fairbault Harley which is about 40 miles away from me. So needless to say my question is will I be ok putting these miles on without a correct tune for the cam? i would guess it just may not run the best of its capabilites but should not hurt anything correct? Thanks
40 miles? I don't see any problem. I have the TW-555 woodcam installed, rode it for more than 150miles with stock ecu, no problem and lots of power. Of course you will get the best out of it after a proper tune. My bike runs a lot smoother after my PV ecu reflash, I am still waiting for my next major performance mod and dyno tune it right.
Its more about timing that fueling with cams on newer bikes. You need to swap to a map on the SEPST that matches the cams you fitted. You aren't going to find a canned one for a SEPST unless they were SE cams.
Chances are it's not going to blow up on the ride home but I definitely would not consider running it like that for any length of time.
Chasingdrakes (05-20-2021)
