Fork size question
Old 04-26-2013, 08:59 PM
Midlife Rider44's Avatar
Midlife Rider44
Midlife Rider44 is offline
Default Fork size question
I have a 94 wide glide. Trying to buy turn signal clamps for the front forks. When I measure around the fork, I get 5 1/8 inches. I convert circumference to diameter and inches to millimeters and I get over 41 mm's. From reading some other threads, it seems stock forks for my bike should be 39 mm's. Am I measuring something or doing something wrong?
Old 04-27-2013, 03:30 AM
milesvdustin's Avatar
milesvdustin
milesvdustin is offline
A millimeter js a tiny amount. May just be the difference error in your tape. I do believe that 39 mm is your size, but I would check with the dealer or Indy to be sure.
Old 04-27-2013, 06:16 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
The other dynas were 39mm. The wg's were 41mm.
http://www.motorcyclemetal.com/gpage25.html
Old 04-27-2013, 06:46 AM
Midlife Rider44
Thanks SC...That explains it.
Old 04-27-2013, 07:30 AM
SC-Longhair
Actually that info is wrong.
It should state that up to 2005, wg forks were 41mm. In 2006, they were upgraded (along with all other dynas from that year forward) to 49mm.
Old 04-27-2013, 07:32 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,923 Likes on 3,022 Posts
My 94' Softail uses the WG forks and they're 41's.
But get good clamps, I've stripped out many. There's not much thread contact.
Old 04-27-2013, 07:35 AM
SC-Longhair
I understand softails are still 41mm to this day.
Hooty420
07-08-2014 01:49 AM
Booey424
06-04-2012 07:20 PM
2006FLST
05-04-2012 06:52 AM
evo
06-06-2007 09:11 AM
imboden
Classic
05-19-2006 04:37 PM
Quick Reply: Fork size question
