Noise in 5th gear?
Noise in 5th gear?
I've got a 2006 Street Bob and I noticed what seems to be a bearing noise (or similar) in 5th gear at low and part throttle. Seems fine in every other gear. Is this just a quirk of the 6 speed gearbox? I bought the bike used a month or so ago with 49K miles on it and supposedly fully serviced.
Seems kinda low to be in that gear, even when I'm lightly cruising I don't shift into 5th until about 50-55 and even then, its pretty low cruising rpms. My guess is you are hearing/feeling some lugging... Never hurt to change out your fluids tho and get some fresh lube in there. Never take the sellers word for anything...
I had heard of the 6 speed noise, but I thought it was at idle and was a rattle. Interesting how the flow for 5th appears to spin the two needle bearings on the main gear drive of a 6 speed. Seen quite a few post of the bearing going out. And also not all of the gears are helical cut. My 5 speed are all straight cut and all a little noisy, but the same, were the 6 speed has a mix of quite helical and a little noisy straight cut so transmission sound different depending on gear range. If you can hear something at 50, it must be loud. All I hear is wind and exhaust. And I run stock exhaust and wear a full face helmet. Get you a stethoscope and add an extension piece of vacuum hose to it. Attach the probe to the transmission and listen to the transmission at speed. May prove interesting. You may have a problem or may not, but noises migrate all over these engines, transmissions and primaries. You really need to pin it down were it is before you think this.
https://www.hdforums.com/forum/touri...-your-ipb.html
To sum up the gears in a nut shell. Straight are stronger, have less hp loss, require little side load bearing surfaces, but have a slight whine at high speed.. Helical are a tad weaker and require side bearings, there for, thinner gears or a wider transmission case. Note that in both a 5 and a 6 speed Harley transmission, all the gears stay meshed all the time, only the shift dogs move.
Guitarded, I also have a pronounced whine in 5th gear. I don't notice it much if I am running through the gears, but more in a cruise. 40 to 50 it really whines, and when it gets warm, it can rival the engine in sound. Sound familiar? I called the H-D mech and he said that that much noise is NOT normal. I am changing the oil this weekend to a heavier fluid, and I am interested in what you are doing for this. Will (H-D) said that if that doesn't quiet it down, I may have a problem. I read that one guy took his new bike in, and they changed the 5th gear and bearings and it was cured. I hope the heavier fluid works. Let me know how you are doing, k?
