Forward to mid controls fxdwg
Old 05-20-2013, 11:37 AM
deedee4150's Avatar
deedee4150
deedee4150 is offline
Default Forward to mid controls fxdwg
Hi I have a fxdwg with stock mid controls..can I convert to mid controls...or is it expensive......
Old 05-20-2013, 11:44 AM
WG2011's Avatar
WG2011
WG2011 is offline
Huh? You have a stock wide glide that has mids they usually come with forwards. I am guessing you meant you want to switch to mids from your current forwards? Its a bit spendy but can be done.
Old 05-20-2013, 01:09 PM
deedee4150's Avatar
deedee4150
Oh yeah I'm sorry it's the herbs damn
Yeah I want to change cause it handle as good as mid controls.......
Old 05-20-2013, 01:20 PM
socialoutcast's Avatar
socialoutcast
socialoutcast is offline
I think its about the same as going from mids to forward. To have a shop do it you would be looking at about $700. This is what I was quoted when looking at a street bob and going to forwards. I just went Wide Glide instead.
Old 05-20-2013, 01:26 PM
cobaltt's Avatar
cobaltt
cobaltt is online now
I put mid mount pegs on my 99 fxdwg. I believe the part #"s were from a low rider. will be a lot cheaper to just add the pegs.
Old 05-20-2013, 04:13 PM
itsteeravfool's Avatar
itsteeravfool
itsteeravfool is offline
You'll need a new inner primary, probably a new outer too. And the mid controls, and all the the parts for an inner primary job.... You're looking at way more than 700 dollars unless you plan on doing the work yourself.
Old 05-21-2013, 05:41 AM
beagle01's Avatar
beagle01
beagle01 is offline
It's easier to just put the mid mount brackets and pegs on but leave the forwards in place. If you have trouble with the leg reach, try a reduced reach kit for the forwards.
Old 05-21-2013, 03:26 PM
atco's Avatar
atco
atco is offline
Hi,
If you dont mind shifting 1st gear up - others down, this is a cheap solution. You get used to it pretty fast. Get a set of used mid controls from ebay. On left side use your fwd shifter but rotate it 180 degrees. Right side just use all mid controls. Cheers from Finland!
Old 05-21-2013, 05:03 PM
Newark's Avatar
Newark
Newark is offline
Originally Posted by atco
Hi,
Seeing this has me thinking. Can you use a shifter that is the style that comes on bikes with floor boards (where there is one arm for toe and one for heel)? Still wouldn't solve the reverse/GP style shifting, but could possibly use if for forwards and mid controls.
dirtdobber
10-28-2011 10:08 PM
Zinje
08-16-2011 10:12 PM
grimreaper169
General Topics/Tech Tips
03-24-2008 10:48 PM
silverbullet2005
06-03-2007 04:04 PM
Larryc5079
04-15-2007 04:49 PM
Quick Reply: Forward to mid controls fxdwg
