Will this take a S&S Teardrop?
Old 02-24-2007, 10:42 AM
Helimad's Avatar
Helimad
Helimad is offline
Default Will this take a S&S Teardrop?
Hi, I had the air cleaner on my 06 Street Bob upgraded last year at the same time as my exhausts. I would now like to change the air cleaner cover and would like to fit a S&S Teardrop. However having removed the existing cover I cannot see how it would fit.
Can anyone tell me what sort of filter I have currently (I thinks its HD)? And what covers it would accept? Am I restricted to using a cover with a bolt in the centre e.g. Arlen Ness Slotted?
Any advice much appreciated -Richard
[IMG]local://upfiles/3372/1E2FFEF50BEB4493A8ADE97826B3DC55.gif[/IMG]
[IMG]local://upfiles/3372/0D30DEFDFFD54B208B1EED886A1FBEA1.gif[/IMG]
Old 02-24-2007, 11:54 AM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Default RE: Will this take a S&S Teardrop?
What you have is a Screaming Eagle Air cleaner,genuine HD.There are allot of one hole covers that will fit it, not sure about S&S teardrop style though.
Old 02-24-2007, 01:57 PM
Helimad's Avatar
Helimad
Helimad is offline
Thanks for that reply. Anyone any idea about if I can fit the S&S cover, or do I have to replace the filter?
Thanks
Old 02-24-2007, 02:23 PM
Cryptoboy's Avatar
Cryptoboy
Cryptoboy is offline
Received 3,877 Likes on 1,415 Posts
ORIGINAL: Helimad
Thanks
I'm pretty sure you'll have to get the matching S&S airfilter (probably back bracket too). The S&S cover had 3 holes to attach to the filter/bracket, and the SE (and Arlen Ness) have center holes for attaching, as you can tell from your pic. Look where the holes are for this S&S cover:
[IMG]local://upfiles/115/A8ACB467551843CC9BB0B7CA5B51AA38.jpg[/IMG]
Old 02-24-2007, 03:34 PM
clayman's Avatar
clayman
clayman is offline
I was going to do the same thing but there are a few obsticles in the way. First the way it mounts, you would have to find a way to center mount the s&s, when you look at the inside of the s&s it has a long cone shape that comes from the center into the air cleaner. This would have to be cut away with a small cut off wheel. You then have to find a filter that will work with your backplate and the new cover and im not sure what is available. In my searching i found that s&s makes a complete kit for new fuel injected bikes, backplate, filter, cover, but its a bit pricey. So i am probably going to go that way. Im sure you can make the cover work, i just opted to stop and wait and go a different direction.
Old 02-24-2007, 05:49 PM
BigJfxdwg's Avatar
BigJfxdwg
BigJfxdwg is offline
If you want the official S&S tear drop you have to get the S&S air cleaner. It does give you more air than a SE or Ness BS1. I think you can get some knock off Tear drop shaped covers that fit the SE.
Old 02-24-2007, 07:45 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
I think there is a CVO teardrop style that may fit.
Old 03-03-2007, 08:44 AM
jamman's Avatar
jamman
jamman is offline
Had to change the complete filter assy , very simple and worth it..
Old 03-03-2007, 10:02 AM
ChiefGator's Avatar
ChiefGator
ChiefGator is offline
Looks good Jam
Old 03-03-2007, 08:20 PM
jamman's Avatar
jamman
jamman is offline
here's a backpic of the license braket Clayman
perryross
Dyna Parts
02-07-2013 08:06 AM
UncleRon
Exhaust System Topics
03-18-2008 09:34 PM
StreetGlider56
03-13-2008 06:01 PM
Paniolo
12-24-2007 12:07 PM
Quick Reply: Will this take a S&S Teardrop?
