Quick question on Fat Bob rear fender
I took my saddlebags off today, but I don't have the shorter stock bolts yet to put it back to stock...I put the longer ones back in but they're sticking out a bit and that chrome piece on the outside is moving a bit. I've checked the bolt, and it won't hit the tire, but is it safe to ride like that?
Are you SURE the bolts won't hit the tire, even if the suspension is fully compressed?
If the strut covers aren't tight (chrome trim loose), chances are the fender support under the fender isn't tight. The supports fall off, you would have a bad day for many reasons.
I would get the right bolts.
Fabrikator
09-23-2012 11:23 AM
