i got a set of pullback risers from j&p cycles. i think they came up 2" and back 1". had plenty of cable and wiring so no other modification was needed. i think the item#5000022 is what i used. around $40.00. the only thing you need to do if you use these is clean the threads before trying to install the bolts. they make the ride more comfortable since you're not sitting straight up on the tank and it takes a lot of the pressure off of your shoulders. it took less than 1/2 hour to install
