Using a lift on a Dyna frame
Ive been hanging around the Dyna section because my wife just bought an anniversary Super Glide Custom and understandably I have things I need to know for example, I've got a lift that allows me to raise my RK but with the motior hanging past the frame on the Dyna's what are you guys using to raise up your bikes?
Use the search and look for Sears red jack modification by SC LongHair. here it is for you.
https://www.hdforums.com/forum/dyna-...ification.html
Im liking the idea of fabricating shims I would use when I lift the bike, I had a similar shim on my wifes VStar. I just need to know where on the frame I need the shims.
Ive got it apart while Im waiting for the apes to arrive and once I put it all back together I will concentrate on the shims. Interesting the wiring doesnt use Molex connectors like the Touring bikes. Im hoping 10" bars wont require throttle and brake line extensions but if its going to be done right it may be necessary......but thats the subject of a diff thread.
