FXDC SuperTrapp install question.
I'm installing a SuperTrapp 2-1 system on my FXDC and am wondering about the stock mount on the front pipe. This isn't covered under the instructions as to if it's to be used or not. It appears that when the exhaust is tightened at the heads that it pulls the pipe into the mount tab. If I loosen the exhaust clamps at the head and use the front mount it holds the pipe out from the front bracket about 1/2" . This seems to put tension on the exhaust system and I'm not sure if I am getting a good seal at the head gaskets. Anyone have any thoughts or experience with this? Did you use the front bracket or just remove it from the engine as it interfered with the front exhaust pipe? Hope this makes sense.
Thanks,
Jerry
Thanks,
Jerry
Update
"P" clamp is a split clamp and there is no way that it is going under the bracket on the engine so I split, top and bottom like I had it before and snugged everything up gradually and it seems to work OK. No noticeable exhaust leaks. The exhaust system sounds great. Can't wait until the weather gets better to try them out.
Jerry
Jerry
Thanks,
Jerry
Michael decotiis
08-16-2014 12:26 PM
