Fork Mounted Signals on 2014 Street Bob
re: wiring
There is a thread on here for instructions. Look for the one "front turn signal relocation". Can be a little confusing, had to read it a couple times my self. A lot easier than it reads. Basically cut the wires from the T. Sig going to the switch housing, pull the wiring harness from the neck (both sides) you will find connectors for the new fork mounted T.Sig to wire/connect into.
Hopefully this link works. Different model but it applies, great write up with pics.
https://www.hdforums.com/forum/softa...fatboy-lo.html
Hope this helped.
Mod on, make it your own! Look forward to your ride pics.
Hope this helped.
This set up does look good! I think I may be going with these though.
http://www.dragspecialties.com/produ...oductId=180655
