New Dual Disc Part Numbers!
#51
#52
#53
#54
#56
#57
You know what's even more irritating? The models least likely to be ridden hard have them, but the Dynas don't.
WTF.
I realize that total weight is part of the reason, but...
#59
New Duel Disk Part Numbers!
So over the week end I took a trip to my local dealer to check out the new Lowrider in person
I have a good relationship with the parts guys so i asked if any of the new part numbers had hit the system yet. Twenty minutes later I had fresh print outs of the front end and front wheel schematics.
I quickly drove home and started cross checking part numbers below are my findings:
Most of the parts that make up the fork assembly use the same 06 and later part numbers or newer versions of the same parts (e.g. oil seal 46514-01 VS oil seal 46514-01A)
The left side fork slider on my 07 Dyna PN# 46608-06 has been superseded by PN# 46608-06B
This part number is also used on the 2014 Lowrider.
the lowrider uses the same axle, wheel spacers as 08 and later Dynas (except FXFD,FLD and FXDWG)
The front fender is the same 06 and later Dynas (except FXFD,FLD and FXDWG)
Fender (primed) 60139-06B
Axle 41628-08
Wheel spacers 11804
NEW Fork Lower Kits!
Gloss Black Lower Fork Sliders 45500273
Chrome Lower Fork Sliders 45500267
14 Lowrider wheel set part numbers
14 Lowrider front 19" Mag 43300280
14 Lowrider Rear 17" Mag 40900289
Caliper and Master cylinder part numbers
Caliper Assembly right-black 44023-00C (07 road king parts book)
Caliper Assembly right 41300002 (14 Lowrider/FXDF)
11/16" Bore Master cylinder assembly black 45105-05A (07 road king parts book)
11/16" Bore Master cylinder assembly 45170-08B (14 Lowrider/FXDF)
Fork Assembly part numbers
Below is the list of parts that make up the fork assembly on my 07 Street bob and the 14 Lowrider
part number differences are shown in BOLD.
4042 SCREW, RIGHT HAND X2
7062 LOCKWASHER, SERRATED LOCK, RIGHT HAND X2
45322-06 HOLDER, FORK AXLE - RIGHT HAND X1
(07dyna) 46080-01 BUSHING, SLIDER X2
(14 Lowrider) ********** BUSHING, SLIDER (NOT LISED AS SEPARATE PART NUMBER)Part of fork rebuild kit 49379-09
46508-01 O-RING X1
46509-01 WASHER X1
(07dyna) 46510-01 COLLAR SPRING X1
(14 Lowrider) 46510-07 COLLAR SPRING
46512-01 SEAL DUST X1
46513-01 RING STOPPER X1
46514-01 SEAL OIL X1
46515-01 SPACER SEAL
46516-01 BUSHING GUIDE X2
46517-01 SPRING REBOUND X1
46605-06 FORK PIPE X2
(07dyna) 46606-06 BOTTOM PIPE X2
(14 Lowrider) 45800042 W/11689 (Piston ring) BOTTOM PIPE
(07dyna) 46607-06 SLIDER, FORK -RIGHT HAND X1
(14 Lowrider) 45500230 SLIDER, FORK -RIGHT HAND X1
(07dyna) 46608-06 SLIDER, FORK -LEFT HAND X1
(14 Lowrider) 46608-06B SLIDER, FORK -LEFT HAND X1
46609-06 OIL LOCK PIECE (1-LEFT - 1-RIGHT)
(07dyna) 46610-06 SPRING X2
(14 Lowrider) 45500243 SPRING
46611-06 COVER, CASE X1
46612-06 BOLT, FRONT FORK X1
(07dyna) 46614-06 BOLT, HEX SOCKET (M14 X 1.25 X 30) X1
(14 Lowrider) 45500118 BOLT, HEX SOCKET (M14 X 1.25 X 25)
46615-06 PACKING SEAL 1
After going over the schematics and part lists line by line
It looks like this mod will be direct bolt on for the 08 and later guys and maybe a trip to Machine shop for wheel spacers for the 06/07 guys
Does any one know the width of the 08 Wheel spacers PN: 11804?
If any part of this sounds incoherent I apologize, I've been going over this for last 12 hours so my brain is cooked on part numbers!
Axle 41628-08
Wheel spacers 11804
46508-01 O-RING X1
46509-01 WASHER X1
#60
you should replace the packing seal but other than that you're good to go double check with your parts guy to make sure
