Anyone have the part number for these or better yet the diameter of the base? Trying to find some riser extensions for them. I know they are wider than most risers.
Well I have them already. I'm just trying to figure out the part number for the official specs. Trying to find a 2"riser extension to give a little extra distance.
he doesn't have the low rider spacers on his list but email him he can probably do them for you. I got the 1" spacers for $40. I'm not using them, hint hint...
Might consider those as an option. What are the inside diameters?
Are you looking for extensions or longer risers? I thought by extension you meant spacers. Don't know the ID offhand but it is sized for the riser bolt. OD is the same as the base of the riser. If I find them this weekend I can post measurements.
Extensions. Unfortunately longer risers are not an option because I have the stock handlebar clamps with idiot light mount. Don't want to risk other risers to only find they won't fit the setup.
I looked years ago for other risers and never found any with the same bolt pattern and spacing for the FXDL handlebar clamp. It was easier to go with the spacers.
Based on what I've seen here, people who do replace their risers and clamp on the FXDL end up relocating or remounting the indicators. Or they just disconnect them and remove them.
I don't have access to my bike, it's still hibernating. I did find the spacers though. ID is about 0.510" and OD is about 1.615" which is slightly under 1 5/8".
