Help/advise removing rear rotor
The MoCo uses aircraft-strength threadlock on their bolts, which explains why they can be difficult to break loose. Some guys have heated up the rotor (not the bolts) to expand the screw hole a bit, but I just give the bolt heads a couple of hits with a hammer, then remove the screws with a 1/2" drive socket wrench. Be sure to use new bolts when re-installing the rotor.
Stand the wheel upright and put the wrench in the 3 o'clock position bolt. Have the wrench positioned so you can push downward across the center of the wheel / axle hole. Hold the tire tight (with your legs) and push down HARD! It's all about leverage. You can always get a longer handled tool. Sometimes the Torque wrench (set to a higher torque than the bolt you are loosening) provides a good lever.
