Dyna frame difference
huh?
wideglide/streetbob 25.5
lowrider 25.4 ( runs shorter shocks)
fatbob/switchback 26.1
all dynas except the lowrider use 12" shocks. if i remember right the low rider is 11.5.
for a whopping 3/4 of an inch difference between all current models.
when you look at the 2 that are significantly different they have less rake, without significantly shorter forks, which pushes the front end up. thus part of the difference in seat height. the seats themselves account for the rest of the difference as the fatbob and switchback have more padding in the seat.
well an 11 inch is as short as they make em. theres a chance you'll bottom out on hard bumps. cranking em up to the stiffest settings will cut that chance down.
if you go with the 11" progressives i'd probably get the HD models for stiffer springs. you should also look into shorter fork springs.
