Squeaking noise on 07 Superglide
Hey guys,
About the middle of last years riding season I began to hear a loud squeaking sound seemingly coming from the rear end of my bike. From what I recall it never happened when I was accelerating only when coasting or at times when I was idling. Not a lot but here and there.
Near the end of last season I put my bike on my lift and fired it up to see if I could narrow it down. Even gave it a little throttle but didn't get any noise. The issue seems to only happen when there's weight on the bike.
I've recently purchased another bike (2008 Rocker C) but will be selling my Superglide to a good friend. I don't wanna screw him by selling him a bike that has an issue even if it isn't a major one. My Dyna has about 20,000KM (12,500M) on it.
Anyone have any suggestions I could check into. My next days off I plan on going for a little rip on it and seeing if I can narrow it down, but it's tough to confirm exactly where the sound is coming from. Thanks in advance.
Thanks.
Yeah, since it only seemed to happen with me on it I thought shocks as well.
Just curious if there's anything I can give a quick shot of a lubricant and rule it out. It's quite intermittent though so something rubbing together doesn't seem right, I would think it would be a lot more frequent if that were the case.
My fatbob starting making same noise after it had 9000 miles on it . verify it was in the rear axle area, did it Constance when the wife was on the back . checked my belt adjustment felt loose went and bought belt tension gauge and measured adjustment with bike on jiffy stand. measured 7/16 readjusted belt tension to 5/16 made sure axle was straight and test drove noise was gone. if your belt tension is ok you better take a look at the rear axle bearings, test ride it and turn sharp back and forth small circles you should hear the noise change in tone in the rear of bike. the bearings are sealed and have probably become dry which is inhibiting the noise.
First chack the brakes, then your belt tension then on a lift spin the wheel and listen for any vibrating or sandy noise. It won't be the axle: it doesn't move only the bearings turn. With those checked if you still come up empty your next area id the mainshaft. I hope you don't have to go there!
salty_rider
04-20-2015 08:56 AM
Dave_B
22
03-18-2007 12:39 AM
