I'm rebuilding the front end of my '09 Super Glide this weekend. I'm replacing the lower sliders (chrome), fork tubes (+2"), and installing Ricor Intiminators. I've got those parts, obviously, as well as fork oil and bushings for the sliders. I've also got a reasonably well equipped set of tools, a bike lift, and a service manual.
Any unusual tools I'm going to need or any tricks I should know?
Loosen the upper pinch bolts before taking the caps off. Also, before you relieve the spring pressure by removing the caps, loosen the Allen bolts with an impact wrench that are on the bottom of the lowers while there is still pressure. The pressure will make it a little easier to loosen the allen bolts. Leave the forks attached and the use the lowers as a slide hammer to disassemble, then undo the pinch bolts and slide them out for the rest of the work.
