120r Fat Bob (A must read)
Old 04-22-2014, 01:08 AM
ebeattie's Avatar
ebeattie
ebeattie is offline
I wonder if Sparco makes a race bucket for your Fatbob. Jebus with this engine your going to need it
Old 04-22-2014, 07:09 AM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
Originally Posted by vdop
Yes. I just bit the bullet on this myself. As expensive as it is, it's cheap insurance compared to having the stock basket grenade and go through the sprocket taking out the crank, trans, primary and possibly causing a wreck depending on how it locks up. Seen it happen.
Had that happen to my father in laws road glide......basket blew sometime after he left the line and it just rattled around inside (luckily nothing else got messed up or locked up).
He went with the Evolution Industries basket paired with the Bandit Sportsman Clutch....so far no problems and Evo Ind. told him that no matter what you throw at it they warranty the unit for 2 years, so no matter what you send it back and they will replace it.
Still rockin w/o any problems.
Old 05-08-2015, 09:45 AM
motolocopat's Avatar
motolocopat
motolocopat is offline
Default What Happened?
So you get the heads back and then just stop?
What happened did the engine grenade itself or not produce the hoped for power or what?
Old 08-01-2015, 07:59 PM
Cfatbob2009's Avatar
Cfatbob2009
Cfatbob2009 is offline
Stage IV
Default Call me when you get the opportunity 615 440 8373
Originally Posted by mademoney101
Had Capital Harley Davidson install a 2013 120r on the bike. made 132.7 hp with 127 tq. Not bad. But knew the 120s are having some issues. So over the winter I tore it apart. Took the bottom end to Hot shot Motor works out of Upper Sandusky Ohio. Dan is the owner there and did the work him self. The crank was out 0.007 and 0.017 on the back. Not good. The balancing was way out to. He welded the crank up balance it and put the hole thing back together. Had a 0.001 run-out when he was done. (nice job). But I didn't stop there. I took the heads to Gillner Engineering out of Parma Ohio. He flow bench the heads then hand ported the M.V.A heads. I will put up flow bench numbers soon.. A quick note lot of guys claiming to get 300cfm out of these heads. not going to happen and Den Gillner has been doing this his whole life. Google him for your self. We installed 12.1 screaming eagle pistons alone with woods 68-G- 7 gear driven cams, S&S roller rockers, billet off set rocker supports. adjustable push rods from S&S. Porter the intake also.installed new 6.2 injectors. This this should make 150 hp all day long. by the way the C.C.P was 196.9. should have bike running in the next two weeks.
.call me when you get the opportunity 615 440 8373
Old 08-04-2015, 04:51 PM
Cfatbob2009
Stage IV
What kind of power did the bike make?
cike
Engine Mechanical Topics
03-06-2014 12:00 PM
Danofxdx
12-14-2013 05:56 PM
jgwoz
09-04-2013 08:01 PM
Kytann
Exhaust System Topics
12-07-2010 04:33 PM
SURFOR Chop
06-14-2009 01:40 AM
Quick Reply: 120r Fat Bob (A must read)
