Just the front true-track stabilizer?
Old 05-26-2014, 05:17 PM
streetpep's Avatar
streetpep
streetpep is offline
Default Just the front true-track stabilizer?
Has anyone just installed the front stabilizer on a dyna without the rear?, Just asking because came across just the front part without the rear for cheap! Called true-track they said they don't recommend it but I would feel the difference, also they won't sell me just the rear,I would have to by the whole thing. Any info is appreciated Thanks!
Old 05-26-2014, 06:20 PM
AndreiTheGiant's Avatar
AndreiTheGiant
AndreiTheGiant is offline
Others have said that the front stabilizer makes a bigger overall difference in improving the ride. Go for it.
Old 05-26-2014, 06:37 PM
Loner88's Avatar
Loner88
Loner88 is offline
Yes, I ran just the front Sputhe for close to 10k miles before getting the rear unit. Noticed a big improvement with the front only. Rear added some more;not nearly as dramatic as just the front. Go for it. If you have a lot of miles on your bike, you should replace the engine mount while your at it.
Old 05-26-2014, 07:16 PM
DonN's Avatar
DonN
DonN is offline
I ran the front for a while as you can do it your self. The rear is a PIA. I believe you can buy the Sputhe rear only. Anyone know if you can mix and match the two?
Old 05-26-2014, 07:58 PM
Loner88's Avatar
Loner88
Loner88 is offline
Sure, don't see why you can't mix the Tru-track with the Sputhe; both the same basic design ( alloy art is the odd duck for the Dyna). No matter what you go with, you are already mixing one or the other with the stock stabilizer mounted on top of the engine.
Old 05-26-2014, 10:21 PM
streetpep's Avatar
streetpep
Thanks everyone, going to give it a shot!
Extreme67
03-04-2020 08:44 PM
16Slim
Softail Pictures
12-10-2016 09:49 AM
Ironhead.Chris
07-08-2015 09:24 PM
jim70
08-16-2013 10:34 PM
dawg
08-23-2011 05:28 AM
Quick Reply: Just the front true-track stabilizer?
