d&d fat cat vs pro pipe high-output
Im still trying to narrow down my exhaust choices..but hard to do so when I cant see in person or hear in person.. comparison between these two in sound? looks I give to the pro pipe in my opinion..sound is what I wanna know..thunderheader I want but the flaws I don't want with it..so what is gonna sound closest to it?
There was a thread either here or over at HTT that had a dyno comparison between the Pro Pipe and the Fat Cat done on the same day, same bike and the Pro Pipe had a very slight edge around 2500 rpm but then the Fat Cat outperformed the rest of the chart. The Fat Cat made about 4-5 more hp and tq(max).
The Fat Cat should have less chance of dragging too.
I'm making the switch over from the V&H Big Shots to the D&D Fat Cats because I want a lil deeper sound coming from the pipes.
Just as a FYI, I ordered the D&D's back on June 3rd & they told me last week they plan to ship the week of June 23rd. I know they do a lot of build to order stuff, not sure if they did a summer shut down, busy or if this is just normal delivery time for them.
Either way you're getting a good exhaust.
i have the pro-pipe
I have a pro-pipe. I really enjoy the sound! I did do the baffle mod so it does have a different sound than a stock one. It is a very deep sound. Everyone that has ridden behind me say it sounds bad ***. The power is great. I ride a lot with two other guys with Dyna's. I can pull away from both of them every time.
I love the sound.
That being said. I do think that D&D has a better product. There black finish is second to none. Thee best in the industry. I think the fat cat sits up a little higher so dragging won't be a big problem. It is a problem with the pro-pipe if you are running a lowered suspension.
I don't think you can go wrong with either.
I love the sound.
Found the Thread that shows the dyno comparisons:
https://www.hdforums.com/forum/gener...o-results.html
Good reading, I think bagger type riders point to the 2000 - 2900 rpm Pro Pipe advantage and the bar hoppers will point to the 3100 - 6200 rpm Fat Cat advantage.
The dyno runs are actually 5 months apart, and it was 22 degrees hotter for the Fat Cat.
I think you'd feel the increase on the left of the curve more than you'd notice the decrease up top. Well actually, I KNOW you'd feel it. That was that particular build though. You know how it goes.
