Dyna Low Rider w/ Power Vision and Autotune
I dont have the PV sitting in front of me right now but I believe the button sequence is, tune vehicle, auto tune, datalog. This should give you a green graph with a "mode" button at the bottom. The green graph represents your VE table. There are several view modes you can cycle through. Press mode until you have the LCOR screen. This is the learned correction in %. You want to keep loading autotune results until you see the numbers on this screen consistently below 5%.
The "hits" screen is fun. Its fun to try and hit the extreme edges of the graph. To hit the high throttle positions at low to mid rpms I put it in 5th or 6th gear and lean on the rear brake a little to slow the rate of acceleration.
I also wasnt paying attention to the VE graph. I was just hitting Log Start and then Log Stop. Next time, once the autotune session is done, I will check the VE screen more closely and then scroll through the different modes and see if I am getting under a 5% change. I know this, right now the bike seems to run very good so its probably not needed....but I love techy stuff. Lol
Keep in mind that tuning the VE table is just one piece of a much larger tuning puzzle. All those other graphs you see in Winpv have a purpose, accel enrichment, decel enleanment, ect. Ect. Ect.
Be very careful adjusting these tables and always save new tunes under a new name.
It looks like you have the right idea. Dont be afraid to experiment, have fun.
I like the techy stuff also, I have a fair amount of experience tuning aftermarket fuel injection on my hot rod, (71 chevelle with a highly modified LS3 style engine). The Harley computer is quite good, the power vision makes it better.
Im a big fan of mounting the PV to the bars. In fact, mine is still on my bars a year later. I like being able to monitor cylinder head temp, AFR, and battery voltage. I even left the wide band O2 sensors hooked up. On many occasions I will adjust the AFR to help keep the engine cool in summer, or lean it out for more mileage on the interstate.
I like to play with stuff..... It's a weakness.
Hi,
I use that same mount from fuelmoto and the visor and never had a problem with it for many many rides,
Also try a map from dynojet if you getting a lot of decel popping, the map i got for my stage1 was really good, it wasnt specific to bike, get the closest one, ie. 96ci, V&H 2 to 2, SE air intake
Thanks
Mirrmu
Thanks
Mirrmu
ghoticov
08-02-2014 06:50 AM
