Considering Auto Tune for a PC V setup
I suspect the auto tune will take this out, but what are the other benefits to the auto tune? I understand if I add different mods, it will automatically adjust, but does the auto tune adjust for elevations, temperatures and other conditions? What are the other things I will benefit from the auto tune?
(I have called Keith for help on the deceleration pop).
Thanks
I've heard all sorts of ideas on stopping this, although I can't speak from experience since I'm thankfully never had the problem. Some find that muffler leaks cause it and sealing with anti-sieze compound or high-heat silicone helps. Others have leaned the 0% column by adding negative values, yet others richening it with success.
So, I don't think AT is the solution for decel-pop issues. Further, I also think that AT is not necessary for most riders, as the Fuel Moto maps are accurate enough to produce excellent improvement in driveability and heat management. AT is for incorrigible tweakers like me and/or people who plan on making cumulative changes to their configuration (cams, head work, etc.).
Closed loop operation has many benefits over open-loop operation. A good dyno tune on an open loop system, even from the best tuner, is accurate at a particular snapshot in time, with a particular tank of fuel, air temperature, humidity, elevation, barometric pressure, air filter condition, engine condition, etc.
You will always get more accurate performance from a system that is able to adjust itself in real-time based on monitoring of the engine.
Whether those differences are 2% or 20% depending on the factors at play, I think a good closed loop system is always preferable. At $300ish, the AT module is the cost of a single good dyno tune.
Moving away from the decel-pop issue now, we should not forget that the stock ECU has the MAP sensor and two temperature sensors that compensate for most of the items on your list above, except possibly the type of fuel. In that case AT won't help since it doesn't auto-tune ignition advance. Call Jamie at Fuel Moto and I believe he will verify this. Furthermore, running AT on my '07 SG from a map created by Fuel Moto showed almost no changes to the AT trim tables. The FM bike was an '07 RK dynoed in WI under colder conditions, 1000' above sea level, and 17% humidity. My '07 SG was trimmed at >50% humidity in much warmer weather and at <50ft. above sea level. This is a testimony to the accuracy and consistency of the map created in one location and run in another, as well as the ability of the various sensors to compensate for temperature, humidity, and altitude.
