Andrews Cams with Screamin Eagle Pushrods
Old 08-11-2014, 04:32 PM
slyedog's Avatar
slyedog
slyedog is offline
Default Andrews Cams with Screamin Eagle Pushrods
Getting things gathered up to do my cams. I can't decide to try and use Andrews Ez pushrods or use the Screamin Eagle quick install that includes the new tubes. I am thinking it will be difficult to adjust the pushrods with the stock tubes and its cheaper to get screamin eagle than get the Andrews rods and but new tubes. I know Andrews did grind the se cams. Anyone do this or reuse the stock tubes and still have room to adjust the pushrod?
Old 08-11-2014, 05:16 PM
VIN1800's Avatar
VIN1800
VIN1800 is offline
I like the SE brands, comes with everything.
Old 08-11-2014, 05:20 PM
kevin_s's Avatar
kevin_s
kevin_s is offline
I just did Andrews 48H cams in mine and used SS quicky pushrods.Only problem I had with the SS pushrods was the shitty blister packing job.I had a hell of a time getting the tubes from the plastic.
Adjustment was simple,the valvetrain is quiet as stock.
Old 08-12-2014, 12:28 AM
latrobedyna's Avatar
latrobedyna
latrobedyna is offline
I done a 57-H cam in my scooter and i just reused the stock rod's. To me it was not worth the extra cost to replace the rods and mess around setting them. When it was easy to just take the tops off the rocker box and pull the rockers. it your time though so is the extra 30 minutes work worth the money ? Hell for the $136.00 they cost i change your cams for ya
Old 08-12-2014, 06:55 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
I like the S/E tapered adjustable pushrods. I used them on both of my bikes with Andrews 48 cams. They are easy to adjust and they provide a complete package, including the tubes and gaskets.
I've never had any issues with adjustable pushrods, and they make it easy to adjust, or change lifters down the road.
Old 08-12-2014, 08:20 AM
slyedog's Avatar
slyedog
slyedog is offline
Good to know. I don't feel like pulling tank and rockers and font care about extra money compared to time. I thought the S&S rods were smaller dia than stock iirc. I will get the se ones with tubes. Now to decide black or chrome? I am thinking black but chrome may be easier to keep clean.
Old 08-13-2014, 12:21 PM
BigMike's Avatar
BigMike
BigMike is offline
Received 1,570 Likes on 674 Posts
What part number S&S pushrods did you use?
http://www.sscycle.com/product/2007-...ushrods-c1077/
Old 08-23-2014, 01:20 PM
slyedog's Avatar
slyedog
slyedog is offline
I have the money now to order my pushrods, clutch spring, and other gaskets, orings, etc. Gary at Andrews said stock lifters should be fine and no reason to swap for just bolting in the 57. I am sure a few swapped lifters while in there but on a 2000 mile motor is the new lifter cost really needed and justified. Been told by few builders stock oil fine and with a lower duration cam with stock valve springs the new lifters not needed. Just waiting for hand to heal and will install. Lifter opinions appreciated as I know a lot of guys on here run the 57.
Old 08-23-2014, 07:22 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
As long as you are using adjustable pushrods, you could always trade those HD lifters out pretty easily in the future if you want to. The stock HD lifters should be fine, there are a lot of better ones but most normal people have budgets and you have to decide where to stop spending - always a hard thing to do......
Old 08-23-2014, 08:48 PM
slyedog's Avatar
slyedog
slyedog is offline
Thanks.That's a good point. Not hard to do them later if needed. The se, woods and s&s are more than I want to bite off if I don't need them with stock springs and rockers. I could bite off the fueling brand lifters though but don't know if any good and again if any better than stock anyway.
Quick Reply: Andrews Cams with Screamin Eagle Pushrods
