How do you install mid controls 2013 Dyna Street Bob
Old 09-02-2014, 01:21 AM
rogersachs's Avatar
rogersachs
rogersachs is offline
Question How do you install mid controls 2013 Dyna Street Bob
I am going to install mid controls . I got a mid outter primary on ebay and most everything needed. Including service manual , bushings and seals, linkage and further forward foot peg mounts.
How can you install the Shifter lever without taking off the inner. If it would require removing clutch its probably above my ability. I am hoping there is a way. Could the shaft be removed and then refasten to the shift lever? Please tell me there is a way- lol . I see the shift lever advertised on ebay, so there must be a way to remove.
I also can feel the tower outlet on the back of the inner primary. Can I drill out the plug. How do I get the shifter shaft bushing in.
I am trying to avoid bringing the bike to the dealer, but if it gets to involved and above my ability may have to bite the bullet-- ugggg. Its very hard to get some one or even the dealer that has done this before.
Would also appreciate if some one would send me a complete list of what I need. I still can't find the spacer for the outside mid control shifter linkage.
Would appreciate all help. I do live in the San Jose area of California. Maybe there is some mechanic who has experience and done this before, especially if this get to involved. Would pay.
Roger
Old 09-02-2014, 05:35 AM
203Cree's Avatar
203Cree
203Cree is offline
The inner is going to have to come off.
Old 09-02-2014, 06:23 AM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
This not difficult to do, just read manual then re-read it, go out and start taking things apart, just have a look around to familiarize yourself with parts etc you will need the 2 sockets for clutch
Its time consuming but an easy task, have to remove battery to loosen starter bolts as well
Thanks
Mirrmu
Old 09-02-2014, 12:48 PM
rogersachs's Avatar
rogersachs
Smile
Cree and Mir,
Thanks for the reply. If I had some one with me with experience at least with the clutch would attempt, but so far nothing. Will wait a week or two to see if something comes up.
If I do it , I want to do it right the first time. Hate to take it down a second time for some stupid , but important part I forgot or did not install correctly.
Hoping some one in my area would contact me.
Thanks,
Roger
Old 09-02-2014, 02:49 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
Hope someone makes contact with you
Thanks
Mirrmu
Old 09-02-2014, 02:54 PM
Juggerpops's Avatar
Juggerpops
Juggerpops is offline
Don't know how to so it but my advice would be dig in but take pics as you go so you have reference for re assembly
Old 09-02-2014, 09:10 PM
camden's Avatar
camden
camden is offline
It's really not terribly hard. Here's a thread I posted when I went from mids to fowards.
2014 FXDB Forward Control Install + Peek Inside the Primary
Old 09-03-2014, 10:39 AM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
You need 150 psi air gun to break the nut loose on the compensator and clutch. On is reverse thread or it used to be.......
Old 09-03-2014, 01:11 PM
rogersachs's Avatar
rogersachs
Cam and Brad,
Thanks for the reply. The thread you posted, including the parts numbers is quite helpful. I did not realize I needed an inner primary gasket kit. Will I also need the engine gasket 34934-06.
Thanks,
Roger
Mac.
03-24-2024 09:28 AM
baxter
05-06-2009 10:31 AM
Raiderse
05-26-2008 04:44 PM
elvissf33
02-28-2007 06:23 PM
83fxrt
General Topics/Tech Tips
01-07-2006 03:56 PM
Quick Reply: How do you install mid controls 2013 Dyna Street Bob
