Turn signals not blinking?
Old 06-14-2012, 07:32 PM
PCKLST's Avatar
PCKLST
PCKLST is offline
Default Turn signals not blinking?
I just replaced both front and rear turn signals with led's and now they do not blink. When turning on signal they just illuminate solid but do not blink. When I turn on the emergency flasher mode all four blink but not when using just turn signal..Will a load equalizer solve this as everything that I have seen says that the lights will flash really fast and an equalizer fixes that but will it also fix not flashing at all?
Old 06-19-2012, 07:29 PM
PCKLST's Avatar
PCKLST
PCKLST is offline
Default no replies?
So I guess for some reason I am some how the only one that has ever had this situation since no one bothered to reply. I added a load equalizer and everything works as it should now, so if anyone has this problem in the future and searches for an answer they will find that yes, the load equalizer does fix this problem..
Old 06-19-2012, 07:40 PM
Glidedsternfan's Avatar
Glidedsternfan
Glidedsternfan is offline
Talking Thanks!
In my defense, this was the first time I've seen this posting.
I wouldn't have known the answer to your dilemma so even if it wasn't the first time I saw it, I wouldn't have had a reply anyway. ;D
But thanks for posting up the solution!
Good to know!
GSF
Old 06-20-2012, 09:59 AM
kicnit's Avatar
kicnit
kicnit is offline
I just went through the same issue. Load equalizer, for sure. If you already havent done it.
kyle
Old 08-01-2012, 09:31 PM
Sam Adams's Avatar
Sam Adams
Sam Adams is offline
Stage I
Where did you get the Load Equalizer?
I'm having the problem.
Also where did you wire in the Equalizer?
Old 08-08-2012, 03:03 PM
04sportster04's Avatar
04sportster04
04sportster04 is offline
Here is an example
http://www.customdynamics.com/loadequalizer.htm
Instructions too....
rgilkerson
Electrical/Lighting/Alarm
03-22-2020 09:13 PM
Train83
09-12-2017 11:18 AM
cprhed
07-22-2016 04:19 AM
Sledge
11-10-2012 01:34 PM
ultravista
23
01-16-2006 09:50 PM
Quick Reply: Turn signals not blinking?
