cyclerama575, 57h or tw222
Old 08-20-2015, 06:54 PM
xdaltonx's Avatar
xdaltonx
xdaltonx is offline
Default cyclerama575, 57h or tw222
Whos got them and what are your experiance with them?
Im running a 2012 blackline, stock 103, inverted big sucker, bassani road rage mega power, and a power vision. I ride between 2200-4700rpm looking for a bump in that range and cant decide between the cycle-rama 575, woods 222 or andrews 57h.
I see the 57h comes on a little later but runs out nice. The 222 comes on early but drops off a little early. And the cr575 looks like it comes on early and carries out pretty well, but have had a hard time finding a lot of info on them.
Whats everyones take?
Thanks in advance
Old 08-20-2015, 08:33 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
At that rpm TTS-100 cams would be my choice.
Old 08-20-2015, 10:08 PM
xdaltonx's Avatar
xdaltonx
xdaltonx is offline
Can i get more info on the tts100. I have tried searching them and cant find very much at all
Old 08-20-2015, 10:38 PM
Nitro 54's Avatar
Nitro 54
Nitro 54 is offline
Here. you can compare 3 different cams to each other
http://www.bigboyzcycles.com/tccams.htm
Old 08-20-2015, 11:58 PM
xdaltonx's Avatar
xdaltonx
xdaltonx is offline
Well i just read the whole thread on cam numbers and what they mean. And used the site to compare the 3 but i honestly dont have enough understanding to make sense of it. Ill keep trying to learn what they mean.
Old 08-21-2015, 07:55 AM
Nitro 54's Avatar
Nitro 54
Nitro 54 is offline
What are you expecting from a cam swap?
Old 08-21-2015, 08:32 AM
xdaltonx's Avatar
xdaltonx
xdaltonx is offline
Just looking for a power bump between 22-4700 rpms. Nothing crazy. Just some more usable power
Old 08-21-2015, 10:27 AM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
Haven't seen the specs on the TTS 100 cams but have seen some dyno sheets and it looks very much like the Andrews 48 or the SE 255s; most interested seem to be those with trikes and/or that tour with a trailer but that doesn't mean it isn't a good alternative for other configurations.
Of the cams listed, stock compression, no headwork, the CR 575 would be first choice, 222 second and 57 last; the 57 really needs more than stock compression to work well. JMHO.
Old 08-21-2015, 11:12 AM
xdaltonx's Avatar
xdaltonx
xdaltonx is offline
I noticed the same about the tts100. Mostly in trikes. My blackline is farely light for a softail. I was thinking 575 over the 222 as well. Have had a hard time finding much info on it though
Old 08-21-2015, 01:54 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
My buddy had a set installed in his 14 FLHX with exhaust and fresh air cleaner. It does EXACTLY what you describe you want, big bump to 100tq@ 2200- 4700 rpm peaks at 115tq. They flat out work. But hey if you guys think they are only trike cams, don't use em..................
Quick Reply: cyclerama575, 57h or tw222
