oil won't go drain into tank
Changing oil on my Blackline lastnite. Took out tank drain and filter and let it drip for hours. Put drain plug back in and went to bed without filter installed. this morning I put the filter on and proceeded to add oil. Only 1 quart would fit in. I figured I had an air block so I spun the engine several times. No luck. So I started it. Oil level stayed same. Cracked filter and let some oil out. Tank level didn't change.. Now What..... Thanks for any help.
Missed that you are a Softail. Drain for oil tank is in cross bar behind and below transmission. You should not pull any crankcase plugs. Especially the tapered pipe one. The case area is very thin there and a 1/2 turn too tight will shatter engine block. Someone did that not too long ago. The NPT one and is used to check for sumping and goes into the cam galley.
Go buy yourself a factory service manual, there's a good chap. You've plainly done something wrong and the book will put you right.
