new 124 S&S difficult to firing,starting
Old 05-05-2016, 01:21 PM
jumpyrk's Avatar
jumpyrk
jumpyrk is offline
Stage IV
Default new 124 S&S difficult to firing,starting
Hello from Palma de Mallorca spain
I have a road king 94 . I just fit a 124S&S engine with electric decompression
new 1.4 kw spyke and a Avr 350 acc gel new battery.
Cold starting impossible , starting take to much amp at the battery, (battery cables are ok) ,
The engine is turning but not starting , with other battery add to bike battery star well.
Some ideas?
thanks
IN advance
Jumpyrk
Old 05-06-2016, 06:52 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Hi from the UK and welcome to HDF. I have an S&S engine and have no problems starting it. It sounds as if your automatic decompressors are not working properly. I recommend you talk to your S&S supplier for help solving this, it is probably something very simple.
Old 05-07-2016, 09:58 AM
jumpyrk's Avatar
jumpyrk
jumpyrk is offline
Stage IV
thanks for help.
By the noise they do ,when I push on start bottum, with cable from bendix disconnect a the starter., I think the are working.
I have been in contact with poeple who sell the engine, daeler S&S, but still waiting,
Jp
Old 05-07-2016, 06:29 PM
PWMORRIS's Avatar
PWMORRIS
PWMORRIS is offline
All ***** 1.7 starter, and Antigravity 24 cell lithium battery.
Push the button and smile....or put in EZ start S&S cams....
Old 05-08-2016, 01:10 PM
jumpyrk's Avatar
jumpyrk
jumpyrk is offline
Stage IV
thanks all
PW morris. what do you think about compyfire Gen III starter, it's suppuse to draught only 175 amp for 2kw it has a 6 to 1 gear inside ?
Old 05-09-2016, 06:08 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
In all situations like this, always insure the battery is in very good condition first, then work outward from there.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 05-09-2016, 07:26 PM
PWMORRIS's Avatar
PWMORRIS
PWMORRIS is offline
Originally Posted by jumpyrk
thanks all
Compufire is part of a conglomerate http://www.pertronix.com/ that owns Spyke (your current 1.4), compufire and many more electric brands.
Never tried that particular starter but as said, it starts with a strong battery that doesn't drop hard at first hit, then work from there.
If you want a bad *** 2.0 starter, the Tech Tornado is the ticket but it goes hand in hand with a real strong CCA battery.
If you can't afford or don't want the lithium I mentioned, Odyseey has upgraded their battery line up and improved their longevity. Since its a bagger, you could run a pc925, or even a pc680. They are just so damn heavy though, but maybe you don't care.
What ignition are you running?
Have you set it to delay a couple revs till firing?
Your set up as installed is not what I would run for a 124", and I have run several big motors on the street.
It's not just firing in your garage, but hot heat soaked restarts out somewhere in the summertime and consistent reliability that is the ticket.
I have tried everything, including running two batteries, so I have played this game for a long time....
Old 05-09-2016, 07:36 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,922 Likes on 17,475 Posts
350cca is too small a battery you need at least 450 for that beast.
Old 05-10-2016, 04:54 AM
grbrown's Avatar
grbrown
grbrown is offline
Once my S&S 107" was run in the starter clearly had an easier time turning it over, but as mentioned already, your new engine will require a lot of power to turn over, both from the battery and the starter. I agree that it sounds as if your set-up is not up to the task of giving your new engine a reliable start in life.
Old 05-10-2016, 05:20 AM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
I agree that it's probably a battery issue. You need more CCA for that motor.
Quick Reply: new 124 S&S difficult to firing,starting
