Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I live in a pretty hot area and do double duty. Jagg fan assisted oils cooler (you can get non fan assisted as well), good pricing available with searching. I also run the Wards fans. I'd say the fans make for a more noticeable difference, but I do like having the oil go through more cooling area as well.
