Evolution engine crankcase breather filter. Fit one or not?
Old 01-03-2010, 07:47 AM
Olias's Avatar
Olias
Olias is offline
Default Evolution engine crankcase breather filter. Fit one or not?
After surfing through various topics/threads & places to post this, I figured here was best.
I have a 1996 Evo FXSTC. 24,000 miles. Can anyone advise regards whether or not to fit a crankcase breather filter to it?
The standard set up (i.e. back into the air filter) is what it has at the minute. The bike often has small drops of oil on top of the gear case (timing housing) and after a hard(er) ride, oil mist has blown back over the frame & oil tank (a little bit) but other than that, the bike runs very well, it's not a hassle. I know Evo's do this and I've had a few that 'spurt' from the air filter... Just getting fed up wiping it (LOL). If there's a mechanical benefit..... so.....
Why should I fit one?
What are the benefits/drawbacks?
Does anyone have tips on fitting?
The best filter to buy? Reed valve (at a bit silly prices) or the basic £15.00 ($20ish) jobs?
Location of filter and bracket? (was thinking height here being a gravity fed oil system?). Does it matter??
Any info/opinion is MUCH appreciated. Thanks folks.
Old 01-03-2010, 11:30 AM
sqdealgeorge's Avatar
sqdealgeorge
sqdealgeorge is offline
I run a Unifilter (3/8 male connector ) off the breather at the back of the right engine case to the frame just below the oil pump Let it drip As far as the reed valves I do run one on my 96CI S&S motor I don't think it makes any more power etc etc I do not like the breather hoses going into the back of the air cleaner I know your 1996 breaths through the heads but you can get connectors to route this away even though my 1993 FLHS still breaths into the air filter Proper oil level in the oil tank can prevent (somewhat ) oil blow by
Old 01-03-2010, 03:31 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
I'm surprised someone hasn't invented a small catch pan that mounts to the back of the air cleaner to catch the oil. You might have to dump it out every 1k miles or so, but it beats cleaning the bike and your leg.,,
Old 01-03-2010, 06:23 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
No filter, just the hose routed down the frame rail on the right side, never see any oil under it when it is parked in the garage, and no oil is on the bike. Been working fine like that for 21 years now and 125k miles. Engine is a case breather.
Engine has no mods other than ev27 cam and Mikuni carb.
Old 01-03-2010, 07:11 PM
gsxrboy96's Avatar
gsxrboy96
gsxrboy96 is offline
i dont know why this is such a big fight with evo owners, run a arlen ness big sucker plate and let the motor take in crankcase pressure and oil droplets, it burns if off anyway, rather than putting it on the ground or the side of your bike.
Old 01-04-2010, 02:01 AM
Olias's Avatar
Olias
Olias is offline
Many thanks for the replies people. All much appreciated. I had a look on the net at that Big Sucker kit but it looks like the filter element is too open to the kind of weather we get in the UK. Lots of feckin' rain!
I'm pretty sharp at keeping the oil level as spot on as I can and I think the connector to route a pipe from the filter could be the way to go.
Thanks again!!
Old 01-04-2010, 02:04 AM
JustDave71's Avatar
JustDave71
JustDave71 is offline
you can put a different AC cover on it...pretty sure, or bag the element like some do with heavy breathers and the like.
Old 01-04-2010, 12:32 PM
sqdealgeorge
Plus 1 on that big sucker hi flow air filter If you're not going to change the top breathing system go get mr. Ness's big sucker CCI's P/N is 04935 and get an HD air cleaner cover P/N29138-91 Keep riding in the rain and get a horsepower gain !!!! Oh how clever
Old 01-04-2010, 12:37 PM
JustDave71's Avatar
JustDave71
yer a poet and didn't know it.
hey...about crank breathers...how come they don't just route back to the oil tank?
Old 01-04-2010, 06:18 PM
sqdealgeorge
Justdave71 Well how could the HD oil mfg's sell more oil ??
Quick Reply: Evolution engine crankcase breather filter. Fit one or not?
