88 to 107 stock crank
From bagger configurations to blvd. blasters.
Good headwork is key to exposing the power on those.
Didn't know is you knew that you can go to 98" w/o spittling the cases on that bike?
Set up correctly, they are no slouch.
BTW, we are shipping a 124" to Calgary next week, same client has a 145" we built/modified for his Dyna.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Its more cost effective to put a 4 3/8" crank in to reach 107. At that point you could do the 4.125" big bore kit and end up at 117. If you have to split the cases i would either put in a stroker crank or at minimum have you crank trued and welded.
But i do hear all bore 107s (4.124"x4") are great motors and make real good power. I had looked into one but my crank had .013 runout. Seeing as i wanted to go gear drive and be able to beeat the snot out of it, that didnt fly and i ended up at 117.
We've been doing that a lot as of late, in the advent of the OE 4" crank being buggered.
117" is a simple as a case bore, and a set of 4 1/8" cyls.
125-130 hp, and 135-140 ft/lbs.
Scott
I currently run an all bore 107" in my '02 FLHT; runs great and wouldn't trade the bike for a new one. However, I regret not goint to 117"; lower unit is out, work is done and the cost to go to 117" is marginal. It's a no brainer.
glide_n_around
Exhaust System Topics
09-29-2010 05:42 AM
