more advice
more advice
OK had what sounded like sounded like bad lifter noise so I did the following
1 Changed lifters (oem)
2 adjustable push rods (s&s to 27 flats 32 tpi)
3 Changed chain Tensioner shoes ( checked bearings and all looks good)
4 Changed primary tensioner shoe
5 Changed oil and filter (Castrol racing RS 20w50 full syn for Harley)
6 Had 3 bad cracks welded up on the head pipe
7 Cut the cone out of the rear of the stock muffler for more sound
Not all of these were because of the issue at hand but still needed done
I need suggestions on what to check next, or should I just take it to a stealer?
Oil pressure when hot is 10-12 when idle and 32-36 at 2500 rpm
Im thinking looking under the rocker boxes
2001 Ultra Classic with 26,000 miles all bone stock
Thinking of ordering this list to try and solve my problem any advice ? Im lost and not sure what to do next, im not even sure this will fix it.
2ea 11270 O-RING 0.88 1.76
2ea 17360-83A ROCKER ARM ASSY 43.80 87.60
2ea 17375-83A ROCKER ARM ASSY 43.80 87.60
2ea 17386-99 GASKET, ROCKER COVER 5.03 10.06
8ea 17428-57 BEARING, ROCKER ARM 1.37 10.96
2ea 17594-99 SUPPORT, ROCKER ARM 32.34 64.68
4ea 17611-83 ROCKER ARM SHAFT 8.23 32.92
SubTotal 295.58
SubTotal 295.58
Don't throw all that money at it. First thing would be to TRY to diagnose the noise.
Thing to remember is that our bikes will transmit noises that would make one think the noise is from point X, when all along it is really from point Y.
Go buy a mechanics stethoscope. Listen around.
When did the noise start? Had you done ANYTHING before the noise started?
How did you check if the PRs were rubbing? What method?
OK, if you buy new rocker arms, the bearings are already inside, and I would recommend buying S&S non roller rocker arms. Better tolerances and comes with bronzes inside. Do NOT but any kind of roller rocker, as those are noisier.
The stock rocker assembly is good enough, also. Don't buy aftermarket, nor SE rocker stands. It's rare to see a bike with 25k miles chew up rockers or rocker stands. I would look elsewhere before moving forward.
What lifters did you buy? Harley lifters from a dealer? The ones they sell, nowadays, are pure junk. WHen they made your bike, the lifters were at least OK, but today, the stock lifters are a known issue. Buy S&S, or Black Ops, or... GMR lifters before you progress any further. I lean towards the GMR lifters, but S&S's good lifters work well, too. And... even tho your bike is a 2001, they sold you lifters from a 2014.
I can't do the math sitting right here, in my head, but.... adjust the pushrods to 130-150 and NOT 100. Just setting lifters deeper will quiet down a lot of issues. You also may wish to investigate HOW you adjusted the pushrods. Mistakes are easy to be made. You HAVE to have the cylinder on TDC to adjust.
Try new lifters (again) and properly adjust pushrods before you blow a bunch of money needlessly. You MAY want to consider buying SE tapered pushrods, too. These had issues in say... 2008, but they have fixed that issue and if the PRs ARE rubbing the tubes? These will help. These SE pushrods are 'quickie installs", too. No need to pull rocker boxes, etc.
I will bet new, GOOD lifters will reduce your noises. Just sticks out to me that you have "C" lifters in there... and that is just such a bad bet, you need to change to something decent. When looking at S&S lifters... they sell two part numbers. I like the premium lifters from S&S. They ARE pricey, tho... but these are one set of very important to the engine, so... after your issues, whats an extra $100 over stock prices. Also, the premiums come in two flavors. Buy the regular, and not the ones with HL2 kits installed inside of them. WIth your engine... no need for 'travel limiters". Black Ops? You can buy those from member BVBOB. GMR's phone number is: 817.741.2000
I waited 30 years or so to get my first Harley and im thinking it wasnt meant to be lol
Update :
First I would like to thank Scott from HillSideCycle.com for being patient enough to talk to me and for the suggestions he helped me with, and everyone here that has been trying to help, I know its hard without actually hearing it yourself and I really appreciate it.
I got a mechanics stethoscope and the noise is at the rear cylinder top very slight at the bottom nothing in the front, the noise has always been in the rear as I suspected.
Things done today:
Drained the oil (Castrol Racing RS full syn) and replaced it with SAE50
Added 2 more flats on the push rods for a total of 29 flats or 4.8333 turns or .145
It did help some and I will be getting the money up for a set of S&S lifters and then go from there, I may take the rockers off and check the play as suggested but I think the lifters are the culprit just funny how the noise is still from the back even with a cheap set of lifters put in. Will post again when I figure out something else.
Things done today:
