hyrdrolocked motor from fuel leaking from carb?
Been busy and have not rode the bike in about a month. About 2 weeks ago i notice a small puddle of gas under my bike. I left the fuel on so i turn it off and think nothing else of it. 2 days ago i go to start the bike. When i go to crank it, just one loud click and nothing. My driveway has a hill so i try to popstart it. Tire will not spin even in 3rd gear. Just locks up. I push the bike up the hill and into the garage. A trail of gas is on the driveway. Im so mad now i just hook up a charger and walk away. Yesterday go to start it. Same thing, hit the starter and one loud clank,like it just cant turn the motor over. So im thinking maybe battery or starter is just done. About an hour later i give it one last try. Starter turns over and it fires fight up. I smell gas, because its pouring out the exhaust pipes. I will go try and start it today just to make sure its nothing else. So we had 2 perfect days here this weekend and i didnt get to ride!
Received 4,317 Likes
If your motor won't spin changing the oil won't do anything except give you fresh oil in your oil tank(which you will need if your motor is sumped).
Granted the gas should have seeped down past your pistons. But if you are getting gas out of your exhaust the cylinder might be full and not allowing it to spin.
What bike is this on?
What carb is on it.
The over flow on the carb might be clogged.
92 dyna glide. stock carb. the bike did start after messing around with it. At the time it wouldnt crank and i pushed the starter, i swear i heard something dripping. but nothing was leaking on the ground. I wonder if the pressure from trying to start it pushed gas out of the cylinder and into the exhaust? then it was able to start?
Gas being pushed from the cylinder through the exhaust valve is the only way you are going to get gas into the exhaust pipe.
I don't understand the last sentence.
Were you able to get the motor to spin/start or not?
cranking it opened the exhaust valve allowing the gas in the cylinder to drain. This made room for air, Without air no combustion.
Like stated, I would drain, or at least check for gas in the oil.
Clean the float bowl and start shutting off the fuel valve.
Or not, your bike. Just a suggestion.
