Exhaust Wrap for Stainless Steel?
I scored a nice used 2 into 1 collector system for my FXR. I'm totally impressed with their stout brackets and very secure mount. They look great, sound excellent, offer a lot of ground clearance, and definitely boost performance.
I was originally considering a high-heat gloss black powder coat for the header pipes. But being that there are no heat shields, I'm considering Exhaust Wrap. However I've read threads regarding issues with exhaust wrap. I've read that it can/will make the pipes rust and/or crack.
These pipes are Stainless Steel so obviously they can't rust. But I'm curious if wrapping them may cause them to crack. I know a lot of you here have wrapped your pipes as well. Any negative experiences with wrapped pipes that you can advise on?
Thanks
Thanks
I, too, would go with your original plan of ceramic coat. I think ceramic coated pipes look great. I was never a fan of wrapped headers, but that's an individual taste issue... oh, and Stainless can rust, by the way.
Rich,
If you ever decide to ditch the rear seat keep them passenger pegs on her. You'll tuck up and under nicely if you ever get the cop fairing. Went to a swapper in September but saw nothing, I'm still on the lookout for ya. 😁
Tom
Tom
Many thanks for keeping a watch out. No hurry though. I've been dropping a bit of coin on this beast and need to recover anyway.
That looks identical to the pipe Big Bear choppers puts on there fxr. I don't remember whose making them though.
On a side not I'm glad to hear Beemer has had good luck with the wrap on his. I had my t-header wrapped for about two years and cracked, and held moisture which cause corrosion. The pipe went unwrapped for close to ten years with out an issue, and I know it wasn't because of mounting. I made my own brackets years ago and you could stand on the damn pipe and it wouldn't budge.
The difference is the ceramic coating. It was done by Jet Hot, inside and out. I wrapped the Thunderheader because I got tired of replacing broken heat shields. Besides that, everyone knows wrap gets you 5 more HP.
