Screaming Eagle or Dynatek 2000 ignition module
Old 03-13-2015, 08:54 PM
sgt_gman2005's Avatar
sgt_gman2005
sgt_gman2005 is offline
Default Screaming Eagle or Dynatek 2000 ignition module
Question for EVO gurus, my buddy is offering me his Screaming Eagle ignition module 32632-96 (8 pin). This came from his 883 and i want to verify if this is compatible to my 96 EVO 1340 Softail (also a 8 pin)?
On this note, i know that investing in an aftermarket is more bang for the buck. are these even the right part numbers for my bike? Anybody had a comparison with these modules:
1. HD SE: 32632-96
2. Dyna 2000: DD2000-HD2E8P
Old 03-13-2015, 11:07 PM
geezerglide007's Avatar
geezerglide007
geezerglide007 is offline
Pretty sure the Sportster ignition module won't work on a big twin. As far as big twin modules for Evo's, I have a few friends that work for Dynatek and they made the modules for all HD's even the Screaming Eagle ones.
Old 03-14-2015, 12:56 AM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
It'll work, but it has more advance (5 degrees more) and a 6800 rev limiter, which you probably don't want to bounce off of too many times. So says Google....
I'd spend a couple of bucks and get a correct, adjustable ignition.
Old 03-14-2015, 05:34 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
I have run both and I think the Dynatek is a little bit better.
At least the bike idles better with the Dynatek.
That said if you are getting the Screaming Eagle for free I would try that first and see how you like it.
I ran a Screaming Eagle for years and I don't have a problem with them.
Old 03-14-2015, 09:16 AM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
His SE is for a Sporty. Yours was probably the correct one.
Old 03-14-2015, 09:20 AM
texashillcountry
Dirt don't hurt
That just means it has a quicker advance curve.
For free I would still try it.
Old 03-14-2015, 09:36 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is online now
Received 2,707 Likes on 1,343 Posts
Yeah, for free, I would try it too. Especially on a lighter bike, it will probably be pretty good.
Old 03-14-2015, 10:03 AM
92Fatty's Avatar
92Fatty
92Fatty is offline
If you run it I'd run higher octane for the added advance produced with module. Especially if your bike already has higher compression than stock.
Old 03-14-2015, 11:58 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,054 Likes on 1,510 Posts
Only if it "Pings" Higher octane is Not good for Performance.
Old 03-14-2015, 12:26 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,816 Likes on 3,318 Posts
Default ?????
Please elaborate.........
Quick Reply: Screaming Eagle or Dynatek 2000 ignition module
