Question about suspension
Old 11-25-2015, 08:38 PM
WindowMan's Avatar
WindowMan
WindowMan is offline
Default Question about suspension
To me it seems my bikes suspension is hard since I feel every little bump
that I hit. I know I can add air to the rear shocks but to what pressure do
most of you use? I'm 185lbs
What can I do for the front ones? Change the oil since I imagine the oil may
be bad since it is a 17 year old bike? What type of oil is best to use on it?
What is the best method of doing this?
Old 11-25-2015, 10:49 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
You should find the recommended air pressures for your suspension in your owners manual. The lower the air pressure, the softer the ride. For example, on my bike, I run zero air pressure in the rear and 10 lbs in the front. Set your pressures per your manual and go from there. When I got my back, someone had 20 lbs in the front and rear and it rode like a wagon.
Old 11-25-2015, 11:03 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
if you have the touring air shocks in the rear you can change the oil in them too. I hear 7 weight is good for a smooth ride. I haven't tried changing it yet, it looks like it helps to have a press to compress the shock upside down with the air valve removed to get the old oil out.
https://www.hdforums.com/forum/touri...y-08-flhx.html
Old 11-25-2015, 11:34 PM
johnod's Avatar
johnod
johnod is offline
Thanks for the link, didn't know I could change the shocks oil.
Old 11-26-2015, 12:28 AM
WindowMan's Avatar
WindowMan
I got so busy with work and my wife being sick that I just ordered my manual yesterday.
I didn't know they had air shocks up front.
Thanks for the info.
Old 11-26-2015, 03:40 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
The topic of suspension expends a lot of hot air around HDF! The air systems, front and rear, get a lot of criticism, partly because they are cheap'n cheerful, not very forgiving, also they don't cope very well when riding 2-up or heavily laden. A few of us have tackled the challenge of improving ride quality, which also improves ride safety, so if you want more info we can help!
Old 11-26-2015, 10:08 AM
WindowMan's Avatar
WindowMan
I think it may be a good idea to change them but will look at doing it sometime
next year, I'll add air for now unless I find it leaks or is damaged, PO may of
have put too much air in them.
I know my wife will not be riding with me anytime with her illness since it will not improve.
Thanks
Michael
Old 11-26-2015, 04:28 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,246 Likes on 5,408 Posts
The rear shocks are very likely toast, and replacement with a nice set of non-air shocks would improve the ride dramatically...you can search for days on which brand is best...but it will come down to how much you want to spend.
Old 11-26-2015, 07:40 PM
langwilliams
if I can find a set of chrome stock air shock take offs I'd like trying to put the lighter fork oil in them an throw them on my V rod. I ride it solo 99.5% of the time an the muscle shocks I picked up are stiff as he!!. It'd be nice to throw some $800+ shocks on but I can't see myself droppin that much coin for shocks. If you ride a lot it's probably worth it but I don't ride a ton an it's normally short trips with frequent stops.
Old 11-26-2015, 10:36 PM
WindowMan's Avatar
WindowMan
Even thou there is only 5000k miles they more than likely are, but I will put
air in then until early next year. But once I do start looking what if anything
should I look out for? What would fit on my bike?
Quick Reply: Question about suspension
