Common source for gear oil leak?
I rebuilt my carb today on my '96 Dyna and took it for a spirited cruise around. When I got home I noticed the distinctive smell of gear oil, but can't find a source. Bike sat in the garage for an hour or two, then I wheeled it back into the driveway. No spots in the garage, but after only ten minutes in the driveway, there was a small puddle of gear oil. I have some light oil leaks, so the underside of the motor is usually damp anyway, so I can't find the source of the gear oil. Where is a common problem area to look at first?
Quad seal, or high gear seal. On my 96 dyna, the IPB race has walked into the high gear seal causing it to leak... a common problem. Unfortunately the fix is labor intensive and I don't care at this point. When I do fix it I'll be going with the baker high torque bearing to remedy it permanently.
Received 19,678 Likes
I just checked it, and it didn't register on the dipstick. I topped it off and guess will have to see how much leaks next time I ride. I looked at the service manual repair and don't think it's something I am willing to tackle. Couple that with my leaky drain plug and the mechanic will be happy.
Received 4,317 Likes
