idles well, won't accelerate
lots of stabilizer in the non-ethanol gas, good connections at the battery and coil, plugs are clean and gapped at .040. Air filter is clean. Sputters when I give it some throttle. Going to go after the Super E's accelerator pump tomorrow. Any other suggestions? I put 200 miles on it after a pro rebuilt the carb and it ran great.
Received 4,317 Likes
Don't need "lots" of stabilizer in the non-ethanol gas just like you shouldn't over oil in two cycle engines, as a matter of fact unless the gasoline is six years old you don't need any stabilizer in it.
Accelerator pump is good starting point followed by timing. Sames strange that the accelerator pump won't be working if "professional" rebuilt the carburetor.
I'd check timing, vacuum leaks, and maybe set the RN12YC's to .038, then wiring to coil and primary wires from coil to spark plugs.
Don't know anything about the "Super E's" but someone will be along shortly that does.
sully (08-05-2016)
sully (08-05-2016)
Yeah, if it ran right before and it doesn't run right now, I think you plugged up a jet. And what exactly do you mean by "won't accelerate"? A non-functional accelerator pump will just give you a bit of a stumble if you crank it, then it will take off normally.
I would drop the bowl and pull the 2 jets, inspect, blow through them.
sully (08-05-2016)
