How much air goes into the suspension
Where are your owners and service manuals?! On earlier bikes like my 1990 Glide the max pressure for the forks is 25psi, for the shocks it is 20 psi. Over the years the specs changed occasionally, but I suspect yours are the same as mine. Think of a number, try it out and adjust from there. It's pointless asking us what we use as we will each give you different numbers!
You can buy a fancy air pump with guage on Ebay, or spend a lot more at a dealer, but none of those were available when I bought my bike new, so I used a small cheap bicycle pump throughout, with a separate low pressure tyre gauge.
I'm going to re-enforce what has already been posted: Get a dedicated air suspension pump. DO NOT use an air compressor!!!! You will blow out the seals on the rear shocks. I wouldn't recommend using a bicycle pump either, because they push too large a volume of air with each stroke. If you're careful the bicycle pump may work in a pinch, but I wouldn't use a full stroke. I picked up a couple air suspension pumps up off Amazon for around $30 a piece, so that's the best solution.
