Adjusting Brake Light Actuator
Old 03-22-2017, 08:03 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,709 Likes on 1,993 Posts
Look on your wiring diagram and look for a common point for all the malfunctioning circuits, usually they will have a common supply point or a common ground. That's where you look.
Old 03-22-2017, 08:34 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
It looks like the oil & neutral lights, brake light, horn, & turn signals are all feed from the ACC breaker. I think that the oil light grounds thru the oil switch (sender unit), the neutral light thru the neutral light switch, the horn thru a ground wire to the frame, the brake thru the bulb socket, and the turn signals thru the bulb sockets.
Old 03-22-2017, 09:28 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,890 Likes on 3,349 Posts
Lets start with the first problem. The rear brake light. You said if you push hard it will come on but not on a light application. That would not be a ground issue. I know for a fact that when the brake fluid is contaminated (moisture) it will mess with the brake switch. That's exactly what happens to mine so I flush the rear and all is fine again for a few years..
Old 03-23-2017, 06:02 AM
Sorg67's Avatar
Sorg67
Sorg67 is offline
I looked at the wiring diagram in the service manual. This is going to take a magnifying glass and some study.
Old 03-23-2017, 06:15 AM
Hackd's Avatar
Hackd
Hackd is offline
Take the wiring diagram to FedEx Office and enlarge it on one of their copiers. I've found it's a lot easier, you can make several copies, and use a colored felt tip to trace circuits.
Basically how I figured out installing the OEM electronic cruise control on my FLHS.
Old 03-23-2017, 09:36 AM
14GuineaPig
Try here: https://serviceinfo.harley-davidson....cle/lookupForm
If the link works for you, then you should be able to get wiring diagrams for your bike. The nice thing about seeing them on the computer is that you can zoom in on sections of the diagram to make viewing easier.
Above is an example of the diagram for your bike enlarged.
Sorg67 (03-23-2017)
mikeh1958
06-01-2015 06:21 AM
clarkchriston
05-21-2014 05:24 PM
Kmarc86
08-31-2013 09:57 AM
HD Bobber
01-06-2012 02:24 PM
Sibs
09-02-2010 03:03 PM
Quick Reply: Adjusting Brake Light Actuator
