do I need a vacuum piston? (slide)
Old 07-23-2010, 01:09 PM
terrapin88's Avatar
terrapin88
terrapin88 is offline
Default do I need a vacuum piston? (slide)
Hey all.
I have been trying to tune in my cv for awhile. I had installed a thunderslide kit and drilled the slide per the directions 2 summers ago. Little by little I have replaced everything back to stock trying to get rid of this on and off lean condition and carb farts. Right now I am at 45/180 on the jets and I am thinking this should be good but its not. I think because I drilled the slide it is coming up too fast and that might be part of the reason I cant get things where I want them. I am going to replace the slide with a stock one and start from scratch with everything stock again.
Good idea? Opinions?
Anyone have a stock slide laying around they don't need?
Thanks
Chris
Old 07-23-2010, 04:49 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,686 Likes on 1,098 Posts
Uh, you drilled the plastic Thunderslide?
Old 07-23-2010, 05:17 PM
terrapin88's Avatar
terrapin88
No, sorry, I had a brain fart. I installed a dynojet kit, not a thunderslide. But the dyno kit told me to drill out the vacuum hole in the slide to make it a little bigger. Aside from an SE AC, V&H pipes and the abortion I made out of my slide, the bike is stock. I want to stay with the 45/180 combo, just replace the slide with a stock vacuum piston or slide that I definitely will not drill.
Sorry for the confusion t150vej.
C
Old 07-23-2010, 05:40 PM
t150vej's Avatar
t150vej
t150vej is offline
Oh, OK... had me shook up there for a minute
I've done a lot of experimenting (and continue to do so) with combinations of "performance" CV parts and honestly, it's hard to beat OEM or something real close. I don't use a dyno just go by feel and plug reads and a drilled slide will work, but much better suited for either "on or off" throttle or a bar-hopper ride... if the bars are real close together.
Assuming you don't have a really tall cam, with a stock slide, needle (of about any size) and stock spring, a 175 may give you better mileage and will pull just as well. Problem with the drilled slide is that it raises more quickly as well as pulls higher with less vacuum. This causes you to have to run a bit richer than necessary just to overcome the imbalance of intake velocity between the slide and butterfly which is directly responsible for fuel input at the needle/main jet.
Ok, long story short - yes, get a stock slide and preferably a stock needle and jet holder (emulsion tube) and go from there.
Old 07-24-2010, 08:42 AM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
NorthGeorgiaHawg is offline
I upgraded my CB carb with this kit from harley-performance.com. It runs great. I got their Deluxe kit with their "EZ-Just" idle adjustment screw that makes it super easy to tweak the idle mixture.
The kit came with a couple of different idle and main jets. I run the 46 idle (stock is 45 and the next stock step is 48) and the 185 main (stock is 175) - which for Bertha seems to be a perfect combo. Idle response is crisp, and she pulls strong all the way to redline.
The kit also comes with a replacement slide needle and emulsion tube. I am really happy with this kit.
Old 07-24-2010, 04:18 PM
pajoe's Avatar
pajoe
pajoe is offline
The best CV set up I had was done by Walley Kerstetter, and back then he also sold a kit with everything you needed if you wanted to do it yourself. He will answer any questions if you email him.
http://www.harleydavcvcarbrebuild.com/
Old 07-25-2010, 08:01 AM
terrapin88's Avatar
terrapin88
Thanks for the replies and the info guys. I appreciate it.
C
Jagg11
EVO
07-29-2022 05:24 PM
Riffraff123
Carburetor Related
03-22-2018 02:22 PM
Quadancer
Carburetor Related
24
04-20-2012 12:55 PM
Toe Knee
03-22-2009 05:37 AM
needadyna
Exhaust System Topics
03-09-2006 02:38 PM
Quick Reply: do I need a vacuum piston? (slide)
