Tappet gide oil leak
Old 05-06-2011, 02:04 AM
Gra490's Avatar
Gra490
Gra490 is offline
Default Tappet gide oil leak
I have a 85 evo which has a leak that seems to be the top of the tappet guide/ bottom of pushrod. what is the simple way to fix it. It seems to be on the inside pushrods only. Do I need to remove the guide? Also I have the chrome tappet guide covers. Can the original guide block be polished or chromed.
Old 05-06-2011, 05:25 AM
95 Ultra's Avatar
95 Ultra
95 Ultra is offline
It sounds like maybe the o ring at the bottom of the push rod covers. I just replaced mine when I replaced the pushrods. They actually had the o rings in stock at the dealer. I'm no expert by far, but I don't see a way to replace the o rings without removing the pushrods. If you have adjustable pushrods that will adjust down short enough to remove, then it'll be a quick fix. If you have stock pushrods, then I believe it will involve some removal of the top end, or bolt cutters. Some of the experts will be along shortly and may know a better way, but it sure sounds like it's leaking at that o ring.
KC
Old 05-06-2011, 05:38 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Could be O ring, could be cracked cases. If its O ring then you need to pull the rocker gear to get the pushrods out so you can replace the O ring....no magic short cuts I'm afraid :-(
Old 05-06-2011, 05:50 AM
JohnFlorida's Avatar
JohnFlorida
JohnFlorida is offline
could be blowback from the carb pooling
Old 05-06-2011, 08:33 AM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
I would clean it up real good and make sure you know where the leak is before trying to fix it. Does sound like the pushrod cover though. But since both intakes seem to be leaking, it could sure be blow back from the carb also. Is the bottom of your air cleaner oily? If it is the pushrod "O" ring, you might try pulling it apart and reinstalling it. Some times that will cure the leak. Maybe just turn the "O" ring 180 deg. Sure beats removing the rockers.
Old 05-06-2011, 01:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Oh, but there is a short cut...
Cut those old pushrods out with a bolt cutter and replace them with a set of quick install adjustable pushrods.
Doubtful that the cases are cracked, cracks between the lifter block mount areas was a problem on the `90 model years and later.
I suggest taking Jim Krafts advice before you do anything else.
Old 05-06-2011, 04:47 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,246 Likes on 5,408 Posts
Before you do ANYTHING!!! Find out what is leaking. Clean area spotless..pressure washer is best (used with common sense...don't hold it too close)...then dry...leaf blower or compressed air. Then spray the entire area with Arrid extra dry deodorant..yep deodorant...it will make a white powder mess...crank engine...it will now be very apparent what it leaking.
Old 05-06-2011, 05:51 PM
Havoc88's Avatar
Havoc88
Havoc88 is offline
Damn, never heard of that one, makes perfect sense.....
Old 05-07-2011, 02:47 AM
Spanners39's Avatar
Spanners39
Or cheap talcum powder....only way to find those leaks.
Old 05-07-2011, 06:07 AM
95 Ultra's Avatar
95 Ultra
95 Ultra is offline
If you have to replace the o rings, I would definetly cut the old pushrods out and replace with quick install adjustable ones, as Dan said. I just installed the Screamin Eagle quick installs in mine. It's an easy job. Comes with simple instructions for adjusting.
Mccula
EVO
30
06-26-2019 08:21 AM
Jumpman
09-09-2018 08:00 PM
hd97fatboy
09-08-2012 10:31 AM
Hoshbosh
EVO
04-15-2009 09:34 AM
TxMoores
Exhaust System Topics
08-02-2005 03:27 PM
Quick Reply: Tappet gide oil leak
