Cam cover change
Old 08-28-2011, 04:54 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,701 Likes on 1,156 Posts
Default Cam cover change
I have done a few word searchs and not being real good on a computer I`ll just ask. To remove a cam cover (changing to a chrome one) the manual says to remove the push rods and lifters. I`m hoping the cover might be changed without goin this far. I`ve gotten stuck in my head I read where the cover could be removed with some caution. What the caution was or is is what I can`t remember. Opps This is on a 1997 FLHT EG There are times my CRS goes into warp drive BG Thanks for time WP
Old 08-28-2011, 05:10 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,555 Likes on 3,058 Posts
The Evo cam cover supports the cam with a bushing. I don't see how you're going to get the new cover on with the pushrods pressing down on the lobes.
You have to remove the pushrods...
Old 08-28-2011, 05:13 PM
miacycles's Avatar
miacycles
miacycles is offline
Yep, the pushrods have to come out. You can cut them with bolt cutters and replace them with adjustables. It will save you a lot of time and effort. Hope this helps.
Old 08-28-2011, 05:35 PM
WP50's Avatar
WP50
WP50 is offline
Was doing a bit reading in the manual. Yup that would be a problem. Thank you WP
Old 08-28-2011, 05:38 PM
WP50's Avatar
WP50
WP50 is offline
That`s kinda what I gathered in doing a bit more reading. Got a brand of adjustable rods you would use? Thank you for taking the time for me WP
Old 08-28-2011, 06:59 PM
2006FLST's Avatar
2006FLST
2006FLST is offline
The HD adjustable ones are good. That is what I run. Went in easily. Dealer should have them for around 100 bucks.
Old 08-28-2011, 08:10 PM
WP50's Avatar
WP50
WP50 is offline
100 bucks That`s not all that bad Now to find some reading (how to) on them Thank You WP
Old 08-28-2011, 08:34 PM
dz1087's Avatar
dz1087
dz1087 is offline
Are you talking about the timing cover on the right side of the engine? I took that off no problem without removing anything but the hall-effect timing plate.
Old 08-28-2011, 08:57 PM
topfuel7's Avatar
topfuel7
topfuel7 is offline
Personally I would just cut the stock pushrods and go the route everyone is telling you but I have heard that If you get the cam at just the right position it does unload all 4 pushrods. If you search around you can get complete directions on this. You use the notch in the end of the cam and set it at a certain spot like 5'oclock or something like that. You can raise the tubes up and feel if any of them has pressure on them. If you push in on the cam when pulling the cover it should stay without the pressure on it. To reinstall you would have to use a bolt in the end of the cam and set up a way of checking end play with a dial indicator since you would not have the access through the tappet block holes.
As far as pushrods, The ones with the tightest or highest TPI which is threads per inch seem to work better. They stay somewhat more lined up when you tighten the nut on the pushrod. Some of the lower TPI rods will kind of **** over slightly when you lock them down. I like the rivera taperlites and they have a high thread count.
http://www.revperf.com/Tech/Instruct...nstruct14.html
Old 08-28-2011, 10:07 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
I used the HD adjustables in mine, and they worked fine. Since you are going in there anyway, I would change out the INA cam brg. to a Torrington. I did mine for peace of mind, although it looked OK.
Quick Reply: Cam cover change
