rear cyl base gasket 93 FLHS
Can you replace cylinder base gaskets without pulling rocker boxes apart? My rear cylinder is starting to weep a fair amount. Read where you can, but was wondering if anybody has done it and what to watch for. Is there a step by step how to some where? I have the Clymer manual and get worn out just trying to find my year and model among the other 10 listed. My rockers are good, ring and cylinders good, just tired of mopping up oil. Any help appreciated
Thanks Scott
Thanks Scott
There is no escape! You need to dismantle right down to the crankcase. Your only decent reference is the factory service manual, use no others! Harley books cover at most a few years at a time and provide a step-by-step.
There are probably videos on the net somewhere, also DIY DVDs. Buy a good quality gasket set and you shouldn't need to do this again.
I would imagine it would be very difficult to fit everything out as an assembled part. It was tight getting just the jug out of mine with no rockers on it. In my experience, when I try to take a shortcut I end up doing it twice or am not happy with the results.
Spend the $60 on the updated rocker gasket kit (comes with both cylinders) and go ahead and do that cylinder top to bottom so you never have to worry about it again.
I read great things about the Hayden Oil Fix, although I just put new James Gaskets in mine.
If you have any questions PM me.
That wasn't a recent big twin! Our Evos and TCs are built like a multi-layered cake (a favourite subject in here!) and each layer of the cake has to be removed to get it out of the frame. So you will need a top end gasket set, which will give you everything you need for both cylinders.
In theory there is no reason that you need to pull the rocker boxes off to remove the cylinder but it only makes good sense to me to break it down and inspect everything. You are talking about an added couple hours to the whole job + the price of gaskets.
You really must stop looking to take short cuts! There aren't any. Buy yourself a factory service manual. Every layer of the cake I mentioned that you can see when looking at your cylinder has to come off, one by one. You are in danger of spending more time thinking about it than it will take to do!
93 FXSTC the rear rocker cover was a biatch to get in and out. Only one combination of tuning etc worked. I used the James kit as well and just took my time. all is well a few years later now and no leaks. I am sure you heard that base gasket leaks on Evos are attributed to putting a load on the motor before it is warmed up. A cold motor running a load is a great way to blow gaskets.
