evo with a kickstart question
Old 03-08-2013, 01:08 AM
greasemykey's Avatar
greasemykey
greasemykey is offline
Default evo with a kickstart question
so i have a 1985 harley evo with a 5 speed trans and a kickstart. the kickstart hits my leg and i have a few times bumped it with the engine running. is there a kit to eliminate the kick start?
Old 03-08-2013, 04:29 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I would guess you need a replacement outer cover. Once the kicker and cover are removed what is left of the mechanism inside will be fine. If you go to Ronnies HD website they have microfiche where you can see the parts for your model year. A little time spent studying them should identify the parts you need. It is far more likely there is a kit for installing a kicker, less likely for removing it! Have you looked on Ebay?
Old 03-08-2013, 05:21 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,233 Likes on 5,406 Posts
Got a pic? There were no factory 5 speed kick starts...so if that is what you have it is aftermarket...there were factory 4 speed kick starts in 85...post a pic and I will tell you what you need to eliminate it....you will get used to it...I like mine...helps me keep my leg off the exhaust.
Old 03-08-2013, 10:18 PM
greasemykey
sorry its a bad pic. its one i took a while back. i had surgery today and cant walk for 3 weeks so this is the best i can do at the moment.
Old 03-09-2013, 04:47 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,030 Likes on 651 Posts
Turtle top four speed? Hard to tell from the pic. Bike doesn't look oem
Old 03-09-2013, 04:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Sounds like recovering from your surgery is more important at present! As therapy you can take a photo of the trans for us later, but take it easy for now.
Old 03-09-2013, 07:09 AM
Tom84FXST's Avatar
Tom84FXST
Yep rotary top 4 speed
you need one of these:http://www.ebay.com/itm/Harley-David...1e2bc3&vxp=mtr
Old 03-09-2013, 01:59 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Just take the kick lever off the shaft....problem solved....
Old 03-09-2013, 02:03 PM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,220 Likes on 4,770 Posts
Sounds like the cheapest simplest fix to me.
Old 03-10-2013, 06:31 AM
Tom84FXST's Avatar
Tom84FXST
Yeah but looks like chit
Quick Reply: evo with a kickstart question
