Oil Pan Drain Plug
Thanks for you insite Dr Hess it's much appreciated. I may have to do that but if I have to take it off I would like to put a new pan back on. My old pan as a pretty good scrape on the bottom of it. I have always worried about a major leak going down the road and not knowing it. Great timing, I had planned a week in the mountains.
I took the drain plug out again to check the threads and out comes the helix coil in 1/4" pieces. The last owner installed it. I dont want a helix where the plug will be removed several times for oil changes. Just going to install a new pan. Tig welding was gonna cost $100, then Tap $___ ETC. I bought a new oil pan for $200. Cost wise not much diffrence and all is new.
When I first changed oil in my '95 Ultra, the threads in the oil pan and transmission case were both stripped. I called the Harley dealer and ask what was the easiest fix. He said a "one" over size plug from AutoZone would take care of both problems. He was right. That was three years ago. The over size plug cuts new threads.
The only cost would be for a tap and new drain plug.
Maybe a couple quarts of oil (or use your old oil if it is still around) to flush the bits of aluminum out, but if you grease the tap and run some low pressure air into the oil fill spout while tapping new threads, I doubt you will get any bits in the oil pan. YD
You're right Dog. After I screwed the oversize plug in, I removed it and poured a couple of cans of sea foam through it to flush out the chips. Friend of mine just bought an evo with the same problem, oil pan threads stripped. Seems to be a common problem with aluminum in these old bikes, but with heli-coils, time-serts, and over size drain plugs, we can fix all these little problems.
