Crane Hi-4 single fire ??
I found a Crane h-4 ignition behind my point cover. Is this a good ignition system? The coil that goes with it is also on the bike. I googled and read the installation instructions and am left wondering why the original ignition module is still riding around on the frame. The installer hooked up the VOES but I have to wonder why? As a side note there was nothing holding the carb on the manifold, it was just pushed into the rubber grommet????? I really love old motorcycles and marvel at what wonderful machines we used to build, and how they are able to withstand some of the crappy maintenance they received. Mike
Yes the Crane is a decent ignition. No one really removes the old ignition module it's really not necessary when you install a system like the Crane or Dyna they're an all in one unit. The VOES is still used by some because it does help in the cruising zone for gas mileage. However it can create a pre detonation issue though. Also the vacuum hose or even the voes it's self can cause a vacuum leak leading to drivability problems. I choose not to use it.
You might want to get an FSM and see what you need for a carb bracket. should not be like that.....
Received 4,317 Likes
If you buy an S&S carb you bolt the carb to the intake with 2 large bolts.
A much better system IMO.
I've had the Dyna 2000 on my 93 FLHS for the past 15 years. No problems whatsoever. It has select-able timing curves, which will also allow the engine to rev above the OEM module. Really nice for those times when you want to 'get on it'. IIRC, mine is set for ~6000 rpms before it cuts out. Only rev'd it that high a couple of times, and when it cuts out, you know it. Definitely something you want, IMO, if you're looking to get all the horsepower the engine can deliver.
